I am doing a cnc conversion for my g0704, I am also replacing the spindle motor with a 2.8hp 130vdc max 2.6hp 111vdc continous DC motor with a encoder on the shaft. I am going to use the DG4s from cnc4pc to control that spindle motor.
I am using 3 KL23H2100-50-8B
570 oz In. Hybrid Stepper Motor
1.8° /200 Steps Per Rev.
5 Amps Current ( Bipolar Parallel),
8-wire, Bi-polar or Unipolar
1/4" dual shaft
for my X Y and Z axis also with encoder for closed loop.
Using 8070D - Digital Bipolar Stepper Motor Driver 32 bit DSP to control each stepper.
Now I calculate the servo motor for the spindle comes out to 17.8 amps at 130vdc, but most likely will only run at the continous rating of 111vdc at 15.2amps or below, and the steppers max 70vdc but more than likely less than 60vdc.
I have a 1500va torrid with two input coils and 4 output coils, on the website it shows 115vac input on two coils, two 58vdc @ 12.9amps, one 18vdc@2amps and one 12vdc@2amps. It also states it can be 115vac or 220vac.
So if I use 220vac will the output voltages be twice what is shown instead of 58,58,18,12 vdc will I get 116,116,36,24vdc?
Will I have to make two power supplies, one for the spindle 111vdc and the steppers 60vdc ? or if used on 115vac can the outputs of to 58vdc be wired in series to get the 116vdc ? If on 220vdc can the 36 and 24 be wired in series to get the 60vdc for the steppers?
