587,990 active members*
4,639 visitors online*
Results 1 to 1 of 1
Threaded View
    Apr 2024
    4
    How to remove cross slide?
    Hey, I have an Emco VMC 100 and I don't know how to remove the cross slide. I have removed all the bolts/nuts I could find, but I can't even budge the cross slide when trying to pull it off. I tried to turn the pulley to move the table as far as I could to the edge, but now it is stuck and doesn't move when I turn the pulley(only the nut moves back and forth, but now it won't even go back through the hole in the apron) .
    ?Does anyone know how to take it off? Do I have to take the pulley and ballscrew off first? If so, how do I take the pulley off? It looks like a keyway pulley, but it impossible to pull of by force, and I am afraid of breaking something.
    ?I also attached some pictures to show my problem.
    Attached Thumbnails Attached Thumbnails 20240515_201220.jpg   20240515_222714.jpg   20240515_222754.jpg
  1. cross slide crabing
    By fragger6662000 in forum Mini Lathe
    Last Post: 12-11-2011, 11:27 PM
  2. Nardini Cross slide
    By clayman in forum MetalWork Discussion
    Last Post: 11-23-2011, 12:57 AM
  3. 9X20 cross slide help
    By bearwen in forum Mini Lathe
    Last Post: 01-15-2010, 03:07 AM
  4. Metal for cross slide
    By arizonavideo in forum MetalWork Discussion
    Last Post: 11-25-2009, 11:37 PM
  5. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-13-2006, 12:09 AM
