587,711 active members*
4,072 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Losing home position after powered down overnight
Results 1 to 6 of 6
    Feb 2008
    13
    Multiplex 630 T32-6 control. Losing home position after powered down overnight. Does not lose position if power is left on. Set tool measure at night and in the morning after powering up is off .0046 on both X axis's and on both Z axis is .0009. Has encoder and scale. Seens to be a scale problem but trying to figure out what is common to both sides.
    Feb 2008
    13
    New limit switches and tried a new encoder. Took out scale and still had problem with x axis if down over night. Seems ok if power is off for short time, batteries read good, checked before power was turned on.
    Jan 2008
    65
    Quote Originally Posted by MTWOLFEL View Post
    your problem is most likely on the piggyback baord on your axis drive amp. this is the board that controls your absolute position encoder. i think that there is also a battery on this board. you could check it first. after replacing it you will have to go thru the procedure to re-establish home position. good luck
    Feb 2008
    13
    Quote Originally Posted by bigbobomb View Post
    Thanks for responding, we swapped out drives and had no change. No batteries on the boards, so we have to re-home on power up.
    Jan 2008
    65
    If you have tried a new encoder and swapped drives with no change then I think the next thing and it seems like the only thing left is the possibility of a bad cable between the control and the encoder.
    Feb 2008
    13
    Thanks I will try that.
  1. T32 Losing position
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-27-2008, 04:57 AM
  2. x-axis losing position...???
    By shnitzel in forum Servo Motors / Drives
    Last Post: 09-29-2007, 06:46 PM
  3. Tormach losing Z position
    By geomagnet in forum Tormach Personal CNC Mill
    Last Post: 05-21-2007, 01:05 PM
  4. losing position in X
    By martsto in forum Milltronics
    Last Post: 03-16-2007, 02:55 AM
