587,908 active members*
4,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > A77 Makino atc shutter door limits
Results 1 to 2 of 2
    Jan 2009
    5
    Hey everyone , I have 2 makino a77 machines that have been idle for 4 years my task is to get them running, so far 4 axis are homed on one unit
    and need to home 7th the shutter door is open how do I set the limits
    Im new so be easy on me
    any help is appreciated
    Apr 2016
    4
    Re: A77 Makino atc shutter door limits
    Quote Originally Posted by vesttr View Post
    Easy fix, Go to Maintenance mode Turn on Maintenance mode, select Shutter, move the shutter to close position. Be careful because if you move the shutter to close position and it strokes out you will get a 7th Axis alarm. Get it real close to the closed postion and set parameter 1815 7th axis APZ to 1 if it is already 1 put it to zero and it will require you turn cycle the power on the machine, go back to 1815 and put 7th APZ back to 1 and she will be set to home postion.
  1. Stop/Start, Jerky, Shutter Movement with Mach3
    By mikefalkner in forum Mach Mill
    Last Post: 04-23-2019, 03:22 PM
  2. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  3. Z axis shutter.
    By neilthib in forum Fadal
    Last Post: 05-31-2012, 02:23 PM
  4. X axis shutter
    By EliteCustoms in forum Fadal
    Last Post: 08-28-2010, 02:35 AM
  5. y-axis shutter series 1 interact tnc-360
    By MSFAB in forum Bridgeport / Hardinge Mills
    Last Post: 07-07-2010, 06:27 PM
