603,864 active members*
6,160 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Image to Sculpture MASTERCAM X3 ART.
Results 1 to 7 of 7
    Feb 2010
    Hi people.
    I am new to Mastercam x3 and would like to know if anyone have done a 3d sculpture from an image. The way the Dog or the girl is done in the following http://www.mastercam.se/mastercam/page.asp?id=7. I will appreciate anyone who can give me a step-by-step process.
    Regards
    If you go to start, programs, mastercam x3 you will see a Documentation folder in there this folder has a Mastercam Art Tutorial PDF file in there. This should show some of the stuff you are looking for.
    Steve Arteman
    www.cad2cam.net
    [email protected]
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Feb 2010
    Hi Steve,
    Thank you so much. I have actually never seen that there so many documentations there. Will study through.
    Apr 2003
    3578
    If you have any specific questions please ask after reviewing the docs. I have done few project or I should say many with Art.
    Example of a project for my wife cub scout den.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Feb 2010
    I read through the tutorial. i was able to make a lithophane but dont know how to output result to surface.
    im quoting from the tutorial "This process is also called 256 gray scale conversion. You set the height
    range, and Mastercam X2 Art sorts the points by gray scale into the
    correct Z level, creating a base surface. You can output the result to STL
    or to Mastercam surfaces."
    i need to come up with a sculpture.
    Apr 2003
    3578
    why do you have to out put to surface as you can cut from the surface mesh right there in Art? the one I did above except the paws were in are art then I pulled up a 2d pockets to do the paws all in the same file.
    Cadcam
    Feb 2010
    Quote Originally Posted by cadcam View Post
    Thank you for the feedback. I am trying to work on my own photo but it wont come out right. too many distortions. the face does not come out smooth. like the girl in the art picture. are you able to make sculptures?
    regards
  1. CNC for 3D Sculpture
    By st45 in forum Machine Created Art
    Last Post: 04-22-2014, 12:22 PM
  2. Import simple image in to Mastercam?
    By VoKuS in forum Mastercam
    Last Post: 02-08-2009, 12:21 AM
  3. image to sculpture
    By gcioffi in forum Uncategorised CAD Discussion
    Last Post: 07-03-2008, 12:42 AM
  4. Replies: 1
    Last Post: 12-24-2007, 01:45 AM
  5. recomend cad/cam software for sculpture prof
    By bfreedland in forum Uncategorised CAM Discussion
    Last Post: 11-04-2006, 06:16 PM
