603,954 active members*
3,223 visitors online*
    Apr 2008
    80
    Cutter Comp in Haas post
    Posting my first programs from my CAM package. I have four canned Haas posts to chose from, two with with cutter comp. The one ending in MM I can see by testing a post is in millimeters. So I am using the other w/o MM. I wish to use cutter comp, however the post starts off with G40 then I never see G41 or G42 in the code. With a typical Haas post with cutter comp on what should I be seeing?
    Can someone post a sample opening block of code with cutter comp on please? I think this would help.
    The comp should change from left and right based on the direction the tool is traveling correct? (outside profile vrs. a pocket)
    Or does the Haas control automatically use cutter comp. in the tool settings page when you enter the actual tool size?
    Thank you,
    Mark
    2005 Haas TM-1, 4th HRT160 - OneCNC XR4 Pro w/4th - Alibre Design Expert
    Metal-tech 4x4 - www.metaltech4x4.com
    Apr 2005
    713
    Hey Mark. What CAM package are you using? Someone may allready have a post they would be willing to share, or you could go to the specific forum for your software on this site and ask questions.
    Starting with G40 is good. It just makes damn sure that no cutter comp is being carried over from a prior operation, especially if you've been messing around in MDI. I have my post set to put G40 before every toolchange.
    This is a typical format for me for the beginning of each tool:
    (END OF LAST TOOL)
    G0 Z.25 M9
    G40 G80 G90
    M6 T2
    M3 S12000
    G43 H2
    G0 X4. Y-2. M8
    Z.25
    G1 Z-.75 F500.
    G41 D2 X3.75 Y-1.875 F85.
    X-.25
    G40 X-.5 Y-2.
    G0 Z.25 M9
    G40 G80 G90
    G53 Z0.
    G53 X-10. Y0.
    M30
    Not correct. G41 is cutter comp LEFT, G42 is, ofcourse, cutter comp RIGHT. Picture looking through the spindle, through the center of the tool, down onto the part. For direction, it's just like sitting in a car...allways facing the direction of travel. You see the edge you need to finish, and you want the cutter on the left of that edge, use G41. In other words, when we drive a car here in the US, we are in the left lane no matter which direction we are headed...that's G41. Japan drives their cars in G42.
    No, G41 or G42 need to be called every time you want cutter comp to be active. G43 must be called every time a new tool is used to set it's length offset from the numbers in the offsets page.
    Apr 2008
    80
    Matt@RFR Thank you for your help on this. I will look closer in the programs tool set up, cutter comp must be there as an option to turn on.
    I am using Alibre CAM right now.
    Thank you for sharing the code it is helpful.
    Mark
    Sample of Cutter Comp in ONECNC CAD/CAM Software
    Hi Helocat,
    First, I am a hobbyist machinist and not a Cutter Comp Expert.
    Matt is correct on his advise to check out a specific forum for you CAD/CAM Software. The sample shown below is utilizing (Machine Comp) in the ONECNC Software. Their are other options and those may require modifications as it relates to the diameter in the offset page of the HAAS control. I would advise you to contact your CAD/CAM Software dealer directly for advise on how to accomplish this.
    I have attached a sample of where cutter comp is established in the ONECNC CAD/CAM system and a sample associated post for that particular operation. It may help you find where it is done in your CAD/CAM software system. I used cutter comp to accurately size the slot in this part.
    Hope this was of some help.
    John
    Attached Thumbnails Attached Thumbnails machine  comp.JPG   Sample comp post ONECNC.JPG   Cutter Comp Simulation Picture.JPG
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Using cutter comp eia/iso on M2
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-22-2020, 03:14 PM
  2. Need Help With Cutter Comp
    By Pmp Audio in forum Fanuc
    Last Post: 07-02-2009, 08:43 AM
  3. cutter comp help please!
    By metlcutr55 in forum G-Code Programing
    Last Post: 02-25-2009, 02:50 PM
  4. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  5. Cutter Comp?
    By donl517 in forum Fadal
    Last Post: 07-03-2007, 02:36 PM
