603,979 active members*
3,468 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > G43 line after tool changes issue.
    Jun 2006
    59
    I seem to be having and issue with it not posting my tool height offset line on Tap and Reaming cycles but it does on all other cycles(Bore, Drill, Peck Drill) as well as any milling cycles. According to the Debug it seems to be missing the Rapid After Toolchange code constructor. Any ideas.
    Aug 2005
    80
    I usually have G43 together with toolchange, not afterwards in "rapid after toolchange".
    The simple explanation is that its not certain that you will rapid after the toolchangi
    Example
    M6 T4
    G43 H4 Z100
    Jun 2006
    59
    Duh! Why didn't I think of that, lol. Thanks a lot.
    Aug 2005
    80
    It's easy to get lost in the complication of a simple problem
  1. tool change issue
    By Diedesigner in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2013, 05:56 PM
  2. MV40E Tool Pot Issue
    By JohnnyTurn in forum Mori Seiki Mills
    Last Post: 06-09-2009, 06:34 PM
  3. Coordinate Line Cad Tool
    By truefordlover1 in forum BobCad-Cam
    Last Post: 08-04-2008, 02:15 PM
  4. Single line font issue
    By pcbmiller in forum Uncategorised CAM Discussion
    Last Post: 03-24-2008, 08:06 PM
  5. Water-Line Tool Path with BCC
    By Kiwi in forum BobCad-Cam
    Last Post: 06-12-2007, 11:36 AM
