603,797 active members*
2,304 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Auto connect the dots?
Results 1 to 6 of 6
    Aug 2005
    828
    Is there a option to automatically connect one point to the nearest next point? What I want to do is import a 2d shape made of points about .1" apart and have Rhino connect all of them one to the next with a Control Point Curve.
    If Rhino can't do it what other CAD can?
    Dennis
    Aug 2006
    133
    Curve>freeform>fit to points (curvethroughpt command). You can tweak some things in the dialog.
    Apr 2003
    1361
    Oh Dennis, you're a funny guy! :banana:
    (all in fun!!)
    Dan
    May 2008
    Hello Dennis!
    A few options come to mind, but since you said you're importing points I'll recommend rhino scripting. I assume you have those points in, for example, a txt file or something alike. In which case you can go like this:
    _interpcrv
    0,0,0
    0,51,123
    0,24,12 (these points don't make any sense, I'm just hitting them as I go along)
    _enter
    This will generate a curve in rhino, after you read the command file with ReadCommandFile (or short "Re")
    Of course, you can use some other form of curve or whatever. Every command in rhino has it's own name, and can be putted in a command file.
    Will this help you ?
    Luka
    p.s. I apologize if my english is a little weird, it's not my main language. If you don't understand something, ask, and I'll try to explain better.
    Aug 2005
    828
    Thank you all the tips, i happen to find a small program a person here on the zone made that convetrs g-code to dxf, so i just fomatted the points as: x123 y123 and it does a perfect job on the dxf file and then open it in rhino and do what I need.
    The zone is great!!
    Dennis
    Jun 2005
    260
    DennisCNC Is that a Rhino tutorial duck I see?
  1. Connect a DDK 57f-50 to PC?
    By bigz1 in forum Computers / Desktops / Networking
    Last Post: 03-12-2008, 01:04 AM
  2. Trying to connect to GREX :(
    By phantomcow2 in forum G-REX
    Last Post: 03-20-2007, 11:25 PM
  3. Connecting the dots
    By monte55 in forum Vectric
    Last Post: 02-12-2007, 01:11 PM
  4. i can't connect with xylotex ?
    By gumush in forum Xylotex
    Last Post: 02-04-2007, 07:57 PM
  5. Best way to connect a Nemo 23 to Acme 1/2-10?
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 11-01-2005, 02:49 AM
