603,891 active members*
5,241 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF- 10,000 or 12,000 is it the same motor?
Results 1 to 8 of 8
    Aug 2010
    For new machine are the only change the parameters
    Same for the rapid feed from 1000 to 12000
    If you know, let me know
    Michel
    Jul 2005
    12177
    When I was looking at the 12,000 rpm option on a VF machine I was told it was a different spindle with higher grade bearings.
    Aug 2010
    I think they have a 12K 20HP Motor for the VM Moldmaker machines and the same motor on the VF series without Gearbox and the 10K option. On the VF- the Motor only run 10K about the parameters. But Attention, they have two different 12K Motors with different parameters (Lincoln/Baldor). Have a look on the label from the motors.
    The most dangerous phrase in the language is:"we've always done it this way."
    Apr 2006
    235
    I think the 12K spindle, if they are same as the ones on the SS and VM, are direct drive while the 10K spindle are belt driven.
    Aug 2010
    Yes, your right, but the question was only about the Motor, not for the spindle.
    Apr 2006
    235
    Quote Originally Posted by GermanTec View Post
    The 12K ones are listed as 30hp, but the non gear driven 10K ones are listed as 20hp. Are they the same motor? There are plenty of stories about how different manufacturers list their horsepower rating. . . but can the same motor couple to different spindles result in different hp rating?
    Aug 2010
    I've only look on the partnumbers from the motor in the sparepartlist.
    In the list is the lincoln 12K Motor for the VM and for the VF, and the Baldor 12K Motor for the VM and for the VF listed.
    But I will ask my sparepart specialist for an answer.
    Aug 2010
    The 12K Motors are listed for VM and VF because there are for the VF-SS Inlinedrive. It's not easy to see only in the sparepartlist. I'm sorry, I miss my brain.
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  3. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  4. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
