587,794 active members*
3,010 visitors online*
Results 1 to 3 of 3
    Jun 2015
    7
    Heidenhain TNC155 Control Do not Turn on
    Hello everyone
    i have "TOS HEIDENHAIN TNC 144" milling Machine .
    yesturday i was runing a program on my machine and it was so close to hit the limit and i had to press emergency button
    after i pressed the emergency the controler do not turning on
    the monitor and the key lights are not turn on .
    although when i turn on the hydrolic , the sound of hydrolic is turn on . thats mean its work but the buttons and monitor wont work
    please help me fast ..
    thank you everyone and so sorry for my bad english
    Feb 2008
    547
    Re: Heidenhain TNC155 Control Do not Turn on
    Back it off the limit switch, then check the switch to make sure it is functioning properly. They have a history of sticking as they get older. You could also have a electrical connection broken or loose.
    Jun 2015
    7
    Dear Scadvice
    Thank u very much .
    i find the problem , 3 of fuses is broke and as i reconect them with temporary 2 string wire , its work
    now i have another problem .
    the ON and OFF switch not working
    i had to connect the power button wire streight together and now i when i want to shut down the muchin i have to turn the main factory power off
    do you know about it ?
    thank u again
  1. Heidenhain TNC155 keeps losing parameters
    By Fudge in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2014, 05:10 PM
  2. Looking for software for Heidenhain TNC155 B/TNC 155 Q
    By Altonjones in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2011, 07:32 AM
  3. 4th axis - Bridgeport 412 + Heidenhain TNC155
    By Fudge in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2011, 04:24 PM
  4. Need help with a Heidenhain TNC155 Post!!!
    By Kim in forum Post Processors for MC
    Last Post: 11-09-2006, 09:31 AM
  5. Still struggling with the Heidenhain TNC155
    By plane magic in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2006, 11:07 AM
