587,593 active members*
3,892 visitors online*
    Jul 2009
    15
    Solid CAM Fail
    I've been using a particular solid CAM file for ages, its set up to do a particular job and has not cuased me any problems until today.
    Today however, when I ask it to export the g-code for any step it gives me this error message:
    "Line 380, error 41828: System variable 'xc' cannot be declared"
    Any ideas what this might mean and how to fix the problem?
    Cheers,
    Chris.
    Mar 2006
    255
    edit gppfile and change all xc to xcnew
    Jul 2009
    15
    pinguS, a big thank you, that's solved it.
    Could you explain why this happened and what exactly changing xc to xcnew in the ggp file does?
    Thanks,
    Chris.
    Mar 2006
    255
    God knows, I read that somewhere, I believe it has something to do with using XC which are used by Solidcam itself, so you cannot declare them?
  1. 325 PROC WDT FAIL
    By ramsey321 in forum Tree
    Last Post: 09-14-2010, 04:47 PM
  2. Fail to generate toolpath!
    By Hawk_08 in forum EdgeCam
    Last Post: 01-28-2010, 04:15 PM
  3. VF2 Turrent Fail
    By jimmck in forum Haas Mills
    Last Post: 06-03-2009, 05:50 PM
  4. DMC 1832 diagnostic fail
    By LyHuy in forum CamSoft Products
    Last Post: 05-16-2008, 04:01 PM
  5. Lube Fail
    By CC714 in forum Fanuc
    Last Post: 01-24-2008, 05:39 PM
