Hi all,
in the process of defining the final size for my machine, and considering that bigger = more expensive, i'm trying to build the smaller, yet usable table size possible for my projects. So, here a standard size for wood and mdf boards is around 1200 x 600mm, but probably the wider material i will machine is somehere around 800 and 900mm, for house doors.
I plan to do also add signs for shops and so, and that's a problem because those could become really long. Now, my question (finally lol):
Is it possible to machine a long piece (longer than the cnc table) by segments? machining a segment, then by some form of marks, or holes for positioning or something else, stop the work, advance the material and continue machining, keeping the two segments in perfect aligment??
Like to read your comments/experiences.
Thank you again.
Rui
