603,417 active members*
3,247 visitors online*
Thread: EMC.var help
    Nov 2011
    137
    EMC.var help
    What is the emc.var file used for and can you change the numbers that are there. im thinking this is for home positions for each axis.I might be wrong, but some one explain this to me.I have my z axis that has a travel of 3.5 inches at the top where i put my home switch to the top of my table. I want to make this point to be -1.0. but i cant seem to change my configuration. this is so that when i place a part on my table i can make it at 0.0000 if i want.
    Jan 2007
    148
    var files are for emc values , home positions etc are stored in the config INI File
    Mar 2004
    370
    Quote Originally Posted by helpmeout View Post
    Assuming you are using the Axis screen GUI, you move to your 0.0 position and click
    the "touch off" button on the screen. It asks you what coordinate you want to set the current
    position to.
    If you want your home position as determined by the switch to be coordinate -1.0,
    you set that in the emc2/configs/.ini file [AXIS_2] section, by
    setting HOME_OFFSET = -1.0
    But, that just sets the MACHINE coordinates, what you most likely want is the workpiece coordinates, which you set with the touch off button. You can set the coords for whichever
    axis is currently selected, and also set that axis coordinate for any one of the 9 workpiece
    coordinate systems (G54 through G59.3)
    Jon
    Nov 2011
    137
    that is what i want to do, thanks so much. I have been able to use the touch-off some today and was able to engrave some letters in some different pieces of wood.Boy am i having fun...
