We have a Frenic FSD-25AR-22 that had 2 blown IGBT's, main fuse, a few diodes, etc. We repaired all this and it ran fine for approx. 50 hours or so.
The other day when braking, it blowed the IGBT's again, main fuse, and a couple of diodes. We repaired it again.
It started and ran fine at various RPM's. When we attempted to stop the spindle the same thing happened. It blowed the main fuse, the same two IGBT's, 1 transistor, and a few diodes.
Any thoughts? We are replacing the IGBT's with the same ones that we took out. (should be original part #)
We have also had the checked the cabling and megged the spindle motor.
Thank you.
