603,899 active members*
2,769 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Sign steps beyond the CNC
Results 1 to 1 of 1
    May 2006
    202
    Greetings router heads.
    As a custom signmaker and contributor to a forums I'm often asked about painting and finishing. It's an essential part of the trade but seldom explained or taught. That's a shame since almost all router projects needs some kind of finishing. The process doesn't need to be complex but a beautiful carved sign can quickly loose it's quality if not finished properly.
    One of the easy and almost fool proof techniques I use is to avoid too much 3d carving. Let me explain: A full 3d panel requires fairly exacting brush techniques if color is added. Most of my work involves pocketing or applied lettering. This technique give a natural sharpness. And it allows me to change easily change up colors. I've also become dependent on the cheap little Critter spraygun which allow for blending. Even when I'm finishing a natural wood sign, ill be blending my stains.
    The attached photo is an example of blending on a wood grained HDU surface. Without the blending the sign looks rather flat.
    Joe Crumley
    Attached Thumbnails Attached Thumbnails Holiday Heighgts 1-0394.jpg   Holiday-Heights2.gif   Galyean-Circle-Family-Edit.gif
  1. IO SIGN
    By CAROLIVAR in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-09-2012, 11:17 PM
  2. Replies: 0
    Last Post: 06-11-2012, 05:50 AM
  3. sign
    By Edwardo in forum DynaTorch
    Last Post: 09-03-2008, 02:56 AM
  4. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
