603,963 active members*
2,472 visitors online*
Results 1 to 9 of 9
    $29.95 Stepper controller
    Has anyone used these drivers?
    http://www.alltronics.com/stepper_motors.htm
    Spec Sheet:
    http://www.alltronics.com/download/20Z028.pdf
    1695
    They don't do microstepping.
    Just curious!
    Because I'm still new at this, could someone explain the advantages and disadvantages of micro-stepping?
    If these controllers dont do micro-stepping, what do they do, large jumps from point to pont?
    Just curious!
    Eric
    294
    They seem pretty good especially for the price. I have the Camtronics board and that is what I have/had used for years before buying the Geckodrives.
    Those drivers do half steps like my camtronics. Basically from what I can tell, your motors are more silky with the microstepping. You will get more resonance (sp??) with the half step (motors will be louder at certain frequencys/speeds). Otjher then that you should be fine. I don't think microstepping really gives you better resolution.
    Side by side the Gecko driven (microstepping) motor sounds silky and the half step motor is just a bit louder. Now I don't mean very loud like your spindle or even cutting. Just a bit louder. Finsh quality on parts....I don't notice a difference between my Sherline and the K2 with the Geckos.
    I say get them especially for that price.
    taus
    Thanks,
    tauseef
    www.cuttingedgecnc.com
    May 2004
    210
    Quote Originally Posted by widgitmaster
    its not a chopping driver so you'll need power resistors to limit the current. The resistors need to be matched to the motor's current if you are driving at a higher voltage and can be fairly expensive for higher wattages (you'll need 2 per motor - Rs on the document). Unipolar only (won't drive 4 lead motors). Also, the spec sheet doesn't say what current it can handle - my experience with alltronics is that they tend to obscure unfavorable information so I would guess it's not very high. I'm always leery of datasheets that appear to be rewritten or otherwise modified by the vender.
    294
    Ahhhhh,, see I learn something new each day!
    thanks philba
    taus
    Thanks,
    tauseef
    Glad I'm still teachable too!
    This "CNCZone" is the best!
    Wish I had found it prior to buying all the stuff for my first CNC router table, my gray hairs woud be a little bit darker, and my budget a bit bigger!
    Eric
    May 2004
    210
    but then, you actually have a machine. I may get a better deal by hanging out here and snagging good deals when they come by but I don't have a finished machine, yet. lol It's always a trade off between better and good enough.
    1695
    Microstepping is needed for a lot more than just noise. If your machine happens to resonate, you will actually lose steps.
