587,311 active members*
3,716 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > hai, i am using NTC hmc with fanuc control, my problem is the feed and spindle overr
    Apr 2007
    7
    Hai, i am working in NTC - HMC with fanuc control, my problem is the feed and spindle override switch works more than 100% also. i dont want these feature. even if put 200% it must work max 100% only. so iwant to know what is the parameter or bit to activate? help me please.
    Aug 2011
    2517
    if you are concerned about operators changing the switches turn the key to disable the panel then remove the key.
    2932
    Quote Originally Posted by a_ravi_tn View Post
    What machine make and model, and what Fanuc model control is this?
    2932
    Quote Originally Posted by fordav11 View Post
    Sorry... what key; what panel? I've seen dozens (probably hundreds) of Fanuc controlled machines over the years, and I can't recall ever seeing a key which disables the panel. Maybe I've missed something.
    In any case, as far as I can tell, he doesn't want to prevent the operators from changing the switches, he wants to limit overrides to a maximum of 100%.
  1. Spindle pulse feed back out of control
    By woffler in forum Mach Mill
    Last Post: 08-18-2011, 01:43 AM
  2. download or drip feed to fanuc -o control
    By oreos40 in forum Fanuc
    Last Post: 12-08-2010, 02:13 PM
  3. Fanuc Om Drip Feed Problem
    By Stebedeff in forum Fanuc
    Last Post: 11-19-2010, 03:31 AM
  4. Replies: 13
    Last Post: 01-03-2009, 05:44 PM
  5. Problem: Feed back on Screen from Spindle
    By northstarr in forum Haas Mills
    Last Post: 06-28-2008, 03:02 PM
