603,942 active members*
2,905 visitors online*
Results 1 to 3 of 3
    Apr 2008
    196
    "Stitch" two programs together
    I an green in the programming dept. I am using VisualMill to machine some oval pockets in delrin. I want to do a roughing pass across my block going east/west & my finishing pass north/south. The only way to do this in visual mill is rotating the part on a 4th axis, which I do not have. I do not want to rotate the part. I could program the cuts seperately & load them seperately, or how would I go about combing the two as one program? I hope this was not confusing.
    Feb 2007
    664
    Remove the m02 from the bottom of the first program then past the second program under the first
    Then trim the fat until you have what you want ,save back ups In case you delete something you need
    Aug 2011
    2517
    CNC programs are just text files. you can copy/paste whatever you want wherever you want. just use copy/paste and any common text editor.
  1. Problem Loading "Sub Cycle Programs"
    By Katoom in forum Hardinge Lathes
    Last Post: 03-16-2011, 09:33 PM
  2. DX32 "Mentor's" [Creating Programs]
    By minton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2009, 05:55 AM
