587,638 active members*
4,351 visitors online*
Results 1 to 6 of 6
    Aug 2005
    78
    Question Fanuc 21T offset problems
    I am trying to assign a totaly differant offset to the same to for a differant operation. Instead if T0808 I used T0818. My problem is that that will not pick up the geometry offset numbers, How would I get it to read the new geometry numbers?
    May 2004
    4519
    How did you determine it is NOT picking up geometry offset numbers? Are you meaning for cutter compensation? Or raw tool position?
    Aug 2005
    78
    When in mdi I call the tool with a T0103 for t1 offset 3 and it does not show up correctly for the absolute position. We have some older machine that will do this(O-T).
    Aug 2011
    2517
    it works. we do it all the time, almost every day in fact. just ensure the geometry offset for BOTH tools are identical. i.e. if using tool 8 offset 8 and tool 8 offset 18 then geometry 8 and 18 must be the same in both X and Z
    2932
    Check parameter 5002 bit 1. I believe it should be 0. This makes the geometry and wear offset both the same #. If it's 1, then the geometry offset # is the same as the tool #.
    Aug 2011
    2517
    I use same tool with different offsets and it works fine here and my parameter 5002 bit 1 = 1 (opposite to what you are saying)
    for 5002 I have 10000010
    it may be a parameter issue though.....
  1. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
  2. Problems with Offset surface
    By 69owb in forum BobCad-Cam
    Last Post: 08-17-2008, 02:06 PM
  3. E1 and G28 codes causing offset problems ?
    By northwestfab in forum Fadal
    Last Post: 10-02-2007, 04:03 PM
  4. Roland JWX-10 Offset Problems
    By lfbrown in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-15-2007, 06:02 AM
  5. FANUC 18i Offset
    By AKamil in forum G-Code Programing
    Last Post: 08-07-2005, 08:56 AM
