603,783 active members*
2,337 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25 lathe Problem
Results 1 to 14 of 14
    Dec 2011
    94
    V25 lathe Problem
    if someone can take a look at this file, when i try to bore the ID it crashes when calculating toolpath, i have never had a problem before, it will calculate it fine if i pick face/rough, of course i want turning rough, and it just crashes each time. any help much appreciated.
    Attached Files Attached Files
    Jan 2011
    380
    When I try and change anything in your file my V25 crashes everytime so I can't experiment. But, thing I noticed was your stock diameter set to 1.25". Make sure that is set to .700, (The size of your drilled hole). That spot for setting your 'stock diameter' is referring to the internal diameter. If it is set to 1.25" it's going to compute something too big and crash. Check and see if that's it. If not I can look some more
    Dec 2011
    94
    ok,i did set internal diameter to.703, i will give it a shot, thanks for the reply, strange that it is crashing you too, this is the first lathe program i have wrote since the update on may 30
    Dec 2011
    94
    same result just crashes, i have redrawn the part, but still dosent change anything
    Jan 2011
    380
    Yeah, crashes every time. But I did a copy and paste of your part to a new drawing, then I was able to create the proper path. Give that a shot too.
    Dec 2011
    94
    nice avatar btw tony, lol
    Jan 2011
    380
    Thanks Yeah, I'm a Linux user
    Dec 2011
    94
    ok i will redraw, and see what happens
    Jan 2011
    380
    I need to read closer next time. I thought you meant your MACHINE was crashing, not Bobcad. Sorry about that Can't find anything in file causing Bobcad to crash, but like I said if I copied your drawing geometry, pasted it into new file window, it was calculating fine without crashing BobCAD. Sheesh, I'm blind sometimes
    Dec 2011
    94
    yeh, it might just be a computer issue,I also really digg Linux, been awhile since i messed with it but very cool, i had a gentoo install workn, if that means anything, lol, bobcam has been acting strange lately , im wondering if i should try a re-install. thanks again for your help
    Jan 2011
    380
    ooo, Gentoo. I'm impressed. Not for the faint of heart I run Debian.
    Yeah if Bobcad has been doing a lot of strange things, it might be a good idea to try reinstalling. First backup your whole data folder to a different folder, uninstall the software. Delete any folders left behind, then re-install it. I've had to do that once in the past when I was getting constant crashes, etc. Not always Bobcad at fault, not always Windows at fault. Just something that seems to get corrupted somewhere.
    Dec 2011
    94
    just did a fresh install, and still crashing when i compute toolpath, if i have system comp on, it will get about 90% done then crash, but if i have machine comp on, it crashes instantly, im out of ideas, i have to wait till tuesday morning to get help from bob-cam, Again thanks for your advise Tony,
    Dec 2011
    94
    i just opened a old file that had a bore operation, re toolpathed it, and it worked fine! i just dont see what could be the problem?
    Jan 2011
    380
    Open this file and see if it crashes for you. All I did was draw box around your geometry, copied it, pasted to a new file. Then created rough and finish passes on bore and its working fine. Maybe there's some type of artifact somewhere on your drawing screen that you can't see, I don't know. Other than that, like you said it's time to talk to BobCAD.
  1. I.D. Lathe Tolerance Problem
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2021, 03:45 AM
  2. Lathe problem
    By Pressco in forum Mastercam
    Last Post: 08-11-2011, 08:36 PM
  3. new lathe problem
    By tjd10684 in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2011, 04:21 PM
  4. Okuma lathe M0 problem
    By pp-TG in forum Okuma
    Last Post: 03-18-2008, 09:51 PM
  5. Problem with 3 Phase lathe
    By pwpeterson in forum CNC Machine Related Electronics
    Last Post: 12-05-2007, 02:54 PM
