587,680 active members*
3,618 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > ER20 coolant thru 32mm body holder
Results 1 to 8 of 8
    Sep 2011
    17
    We have a Star SR-32J swiss and are looking for at least 2 ER20 collet holders with 32mm body that have coolant thru capability. Does anyone know who might make them and/or where to get them or get them modified. Need to have the smaller caps to be able to slide the complete holder through the arm for tool positions 13 and 14. Thanks for any help.
    Jan 2010
    134
    Are you sure you're looking for 32mm and not 22mm?
    Sep 2011
    17
    Yes Absolutely
    Jan 2010
    134
    Check here, call them for the cap diameter, It may be too large:
    http://www.sommatool.com/catalog/col...lletSystem.PDF
    And I'm not sure if they have that size with coolant thru.
    Sep 2011
    17
    Thank you, will post yea or nay later. Good day
    Jun 2010
    49
    holder
    Usually in that situation I would use a standard er20 holder with a global or other toolholder bushing.
    hope that helps,
    Oct 2011
    Quote Originally Posted by DCogswell View Post
    The sr32(j) has two two toolpost postions which are 32mm.
    A sealed collet such as an iscar jet handles up to 1700psi iirc. I have modified 3/4 extensions that I cut real short to expose the m12 stopper screw thread and adapted an npt fitting onto it with success.
    Anything is possible, use your imagination. It doesn't have to be perfect or pretty, it just has to work. To quote red green, "if they don't find ya handsome, they should at least find you handy."
    Cheers
    Jun 2006
    59
    I use rego-fix for everything coolant thru. Their sealing disks, flushing disks, and sealed collets have never failed me.
    Rego-fix 2632.22542 has a 32 mm shank however it is er25 so you would have to remove the nut to get it in/out of the holder.
    http://www.rego-fix.com/pdf/REGO-FIX...Automatics.pdf
    Running 2000 psi.
    Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
  1. runout on er20 collet holder?
    By Teyber12 in forum Novakon
    Last Post: 04-10-2010, 01:58 AM
