603,981 active members*
2,735 visitors online*
Results 1 to 5 of 5
    Sep 2012
    RFQ: Automotive Radiator Bracket
    Brief description of the parts: Aluminum upper radiator support bracket.
    QTY: 20, 50 and 100 units
    Material: 6061 Aluminum Supplied by you
    Finish: Machine Finish
    If the demand for these part goes well, multiple batches will be needed.
    I will need one piece prototyped to verify fitment.
    I apologize in advance for the amateur cad work. Any questions please feel free to contact me.
    Attached Files Attached Files
    Apr 2006
    76
    Maybe others are more knowledgeable than I am, but I don't see how this thing could possibly be made at a reasonable price.
    The profile could be made as a custom extrusion, but it would not have all of the fancy radii and fillets you have designed. This would also require high volume.
    I don't know what you are trying to do, but it looks like you may be trying to replicate a part that is made as a die casting. At your volume, I just don't see how anyone could make these and have them look anything like you have designed.
    Jul 2012
    i agree with uwp wes completely.
    Feb 2006
    196
    Jsann,
    Would you want to consider molding your part from a hi-temp glass-filled nylon?
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    GPM is the professional manufactory in precision machining , can make various material such like mild steel, stainless steel, aluminum , copper, brass , brozne, engineering plastic.
    There's no MOQ limited for GPM.
    Accuracy can reach +/-0.005mm
    Welcome to send us drawing for price evaluation.
    Brant
    [email protected]
    ADVANCE TEAM COMBINE HK LIMITED
    GPM--factory of precision CNC machining, milling, turning, welcome to send RFQ for price [email protected]
  1. RQF - Automotive Bracket 0.125" Aluminum
    By jsann in forum RFQ (Request for Quote)
    Last Post: 09-07-2012, 09:17 PM
  2. PC cooling radiator for laser?
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-17-2011, 03:52 PM
  3. Can a radiator fan motor be used on a Micro Mill?
    By FlyingElectron in forum Benchtop Machines
    Last Post: 04-16-2009, 01:21 PM
  4. Automotive Rim Profile Help
    By greg hoeve in forum Mechanical Calculations/Engineering Design
    Last Post: 10-14-2008, 01:48 PM
  5. RFQ-small (RC) radiator
    By Double J in forum Employment Opportunity
    Last Post: 08-17-2008, 05:42 AM
