587,308 active members*
3,842 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse rt480 - program too big !
Results 1 to 2 of 2
    Hi, I'm trying to solve a problem on a BIESSE
    with CNI rt480 control. The internal ram is only
    1MB and I need to load a cutting program that
    is 1.5MB of size.
    The program can't fit into the internal memory.
    The program can't fit into the floppy disk.
    I have been told that it was possible to add
    a 10MB hard disk with an expansion card...
    The problem is getting a working expansion
    card and an old compatible hard disk !
    I have also been told that it was possible to add
    more memory to the control. The problem is knowing
    which kind of memory and how to place the banks
    of memory, because they need to be placed in
    a specific order !
    Any help is appreciated.
    Jul 2010
    104
    The simplest thing to try, assuming you have already deleted all unnecessary programs, would be to modify your program to accomodate the memory size. With a file that large, I assume you have a CAD/CAM generated program, probably doing some 3D work. With that in mind, you can reduce the size of your program by first, eliminating one decimal place to the right of the zero. Yes, this will make the part "less accurate," but most of us realize that .0009 inches is nothing to sweat about. Secondly, increase the scallop. This will cause a poorer finish, but it's something you may have to do. Lastly, can you drip feed the program? Biggest drawback to drip feeding would be in a production setting; not being able to simply load the part and push go.
    Good luck!
  1. Biesse Rover 346 (RT480)
    By SUNSEEKER in forum CNC Machining Centers
    Last Post: 03-07-2019, 06:50 AM
  2. Replies: 1
    Last Post: 08-08-2014, 02:05 PM
  3. BIESSE ROVER 18 - pc CNC Program edit
    By CNCworldER in forum CNC Machining Centers
    Last Post: 06-27-2013, 02:34 AM
  4. Replies: 2
    Last Post: 12-28-2011, 07:08 PM
  5. updating biesse to new program
    By firebird in forum Commercial CNC Wood Routers
    Last Post: 12-05-2009, 07:44 PM
