As Andrew rightly pointed out, that just doesn't look rigid enough. Your going to get a major amount of vibration on the X axis, and even more so on the Z axis if you plan to cut aluminium. I suspect the noise will be somewhat akin to a screaming banshee.
If your planning on routinely cutting aluminium to any decent degree, the X axis rails really should be the ones mounted on an alu support bar with as much perpendicular support on the frame as possible. I'd also spread them apart as far as possible while still allowing an appropriate depth of cut. I'd also do the same for the Z axis, the end supported rails may look strong, but they have a fair degree of flex. This flex will very strongly manifest when cutting a material like aluminium.
cheers,
Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
