Originally Posted by
johnyac
Thanks to all of you for responding,
I have a choice, new car, or the Mill. So I'm looking at the mill.
As for software, BamCam looks interesting, will give the trial version a run.
Dropping back to the basic package eliminates Sprutcam and gives Cut 2D. But this allows me to buy the 4th axis and the PD now.
Anyone run Cut2D or should I just drop it all together as well?
Not interested in the arms, easy to make. Have a couple of extra lcd monitors, keyboards, and a laptop, no need for more.
As for the type of work wanted, no real direct idea. Enjoy working on a couple of older cars I have. Making small items for them out of aluminum, plastic, and steel, appeals to me. An HVAC mechanic by trade, enjoy making things work right. Would like for the parts to grow in size and complexity as my experience does. The 770 seems like a good fit, far better than the bench top hobby machines.
The Camera really appeals to me just for the gasket demo ran on the Tormach video. I like gaskets, weird that way.
The passive touch probe looks like a faster way to copy parts than using a caliper and drawing in the part dimensions. Is there a better way?
Cost chopping gets me closer to the 1100. But buying it would mean doing electrical work I am not ready for. Adding an exterior load center to the meter socket or double tapping off of the meter lugs (allowed here). I do want to add a panel in the garage eventually, only if this is where I retire.
32084 - PCNC 770 Series 3 - Freight Additional PCNC Oiler: PCNC-A Automatic Oiler $7,059.00
31191 - 770 Machine Stand - Freight Additional $1,184.70
31192 - PCNC 770 Coolant Kit - Freight Additional $512.37
31446 - Lifting Bar $93.21
30290 - 4th Axis Kit - 6" Table $1,287.83
30272 - Tailstock for Rotary Table (Medium) $118.80
31721 - 4 Jaw Chuck for 6" Table $287.90
31520 - Tormach Machine Controller w/Mach3 Machine Controller OS: 31520 - Tormach Machine Controller w/Mach3 $715.00
30616 - Shuttle Jog Controller $84.02
32394 - TTS Tooling for the Deluxe Package $627.75
32284 - CNC Operator's Set with Tool Assistant Set $795.00
32436 - PCNC 770 Power Drawbar $1,193.50
31728 - Power Drawbar Foot Pedal Kit $68.45
31453 - Tormach CNC Scanner Software only $368.50
32309 - Passive Probe w /10mm TTS mount $236.50
31965 - Cut2D v1.5 $149.00
Total $14,781.53
Shipping around $700.00. Cant pull up the exact quote at the moment, but it would be off due to adding the draw bar.
$15481.53
Dropping the Cut2d and the camera software, then adding back in the Sprutcam, gets me just over budget at $16004.03.
32085 - PCNC 1100 Series 3 - Freight Additional PCNC Oiler: PCNC-A - Automatic Oiler $8,689.00
30297 - PCNC 1100 Deluxe Machine Stand - Freight Additional $1,644.50
31706 - PCNC 1100 Power Drawbar $1,193.50
Total $15,382.04
Dropped the Chuck to save a little more, buy one later. No probe or camera software. Minus one tooling package. Add an additional 1000-1500 to install the electrical myself and try keeping totally motivated in the process.
