Hi folks,
I am currently milling, drilling and tapping about 60 side ports in a 6.5" OD 316 Stainless Tube. The holes have a 1" bore and then a series of stepped registers, for mating flanged port inserts. I am chamfering all the flat edges but since there are so many of the ports, I would love to be able to chamfer the rounded outer edge where the outer register diameter meets the tube OD. It seems to me that the 3D arc operation should be able to do this. I imagine, I would need to program in the x/y axis sweep of the register OD (radius 1.5") with its centre on the port bore axis and then also (depending on which quadrant I was programming) the y z or x z axis sweep respectively ( radius 3.25") with its centre on the tube axis centreline. I also worked out an xyz coordinate half way along the sweep.
I tried this with no success. I have worked on fagor machines in the past where you were able to separately input profiles in the xy yz and xz independently so was hoping that the 3D arc operation was similar.
Any advice would be greatly appreciated.
I know that there was a 3D mode option available for the Ultimax III which might have helped in this situation (dont have that section of the manual) but the local (UK Ireland) Hurco rep says that it is no longer available for our machine.
