I have a C10 breakout board from cnc4pc and I have connected one step motor through a KL-4030 driver. If I plug a 5V power source into the C10 board, the motor doesn't move. If I use only the power coming from the parallel port, that motor move. I have measured the voltage coming from the parallel port at 2.45V.
Is it risky to use only the power from the parallel port?
Thanks in advance
