Hi, I know nothing about how vacuum tables work so bear with me. I'm trying to work out how to make a vacuum table for my cnc router. I want to make several pods with foam seals around the edges. Is it the general procedure to have the work piece attached directly to the pod? Is so how do you get round the problem of "overcut" where the cutter cuts deeper than the material and into the foam seal? Or it just a case of setting the Z height really carefully so it doesn't machine through the stock, or do you use a spoil board? But if you use a spoil board then you've got to use double sided tape or something to hold the work piece to the spoil board, but doesn't this defeat the object of using a vacuum table?
Also I was watching a video from Laguna CNC about their CNC vacuum tables- they seemed to infer that the MDF spoil board on top of the vacuum is porous enough to let suction through so you can just lay the work piece on the spoil board and it will hold- is this right?
Any help gratefully received
thanks
Joz
