Hello!
I apologize if I missed the topic where this was explained! I did search, maybe I'm not wording it correctly.
So, I've got a Grizzly version of the X3. I used CNCFusion's conversion kit and electronics from Probotix. It is basically me teaching myself how to do this so I'm mostly ignorant at this point.
I have this problem where the cut will be going nicely but then as the Z axis is being adjusted up it suddenly makes a mistake or stalls or slips (I can't hear the mechanical sounds which would be a huge clue as to what the real problem is) but the LinuxCNC has the end mill's actual Z position wrong and now plunges the end mill deep into the piece being milled.
If I hit the big red button, back the Z out and re-home it and run again it rarely happens again and never in the same place if it does. Its almost like a nervous twitch.
I don't know if this is related but if I set the jog to half speed sometimes the Z axis stalls on up movement. At full speed jog it move very rapidly and never stalls. At half speed it has a lot of vibration.
So, anyone have any ideas or maybe some places to start?
I have micro-stepping set to 2 and the Z axis max travel speed is 30 ips.
thanks,
snz
