603,916 active members*
2,667 visitors online*
Page 1 of 2 12
Results 1 to 20 of 33
    Apr 2003
    598
    V-Carve application? Engine turning
    I think this is an ideal application for the V-Carve software, but I'm not sure. Thought I'd ask.
    I love beautiful watches and clocks -- and this dial is particularly beautiful. It is this type of engine turning that truly appeals to me, but I haven't the slightest idea how to program it. Could anyone help?
    (I'll have to finish a working machine, though, to put it to use!)
    -- Chuck Knight
    P.S. No, this is not my watch. It's a pic off of a watch collector's forum.
    http://img.photobucket.com/albums/v1...lkgulanbcc.jpg
    35494
    Quote Originally Posted by chuckknigh View Post
    I'd guess that it's cast. If you wanted to machine it, make a 3D model in your favorite CAD app and use CAM software for the toolpaths.
    Apr 2003
    598
    Actually, it's not cast at all. Roger Dubuis watches are extremely expensive...and are actually cut using a rose engine. Amazing detail...available for an extremely high price. Not a bad value, as far as high end stuff goes...but still.
    I like the idea of using the CAD...but it's flat, and I wouldn't have the slightest idea how to model something like this...manually. It's just the depth of the V-cut that varies, to change the width of the line. It's an amazing effect, and like I said, it's a perfect application for V-Carve...if I understand the software.
    I'd love to make a clock with a dial like this...not to mention a custom watch or two.
    Imagine it in ebony...or maybe blued steel.
    I think I'll restart work on my micro-X-Y table, tomorrow. :-) I've got a mini air die grinder that I'm dying to try.
    -- Chuck Knight
    Aug 2004
    2849
    It's really hard to tell if that is actually machined or just painted.
    I suspect that the way to draw it is to take a circle with radial lines (200 or 300).....then using some shape...modify the shape of each radial line to conform to that shape or curve...
    Apr 2003
    598
    It's machined. Here's a pic of the whole watch...
    http://www.imagestation.com/picture/...a/fa63a843.jpg
    -- Chuck Knight
    Jul 2003
    586
    I believe that is called Guilloché. The lathes that made that pattern were a wonder to behold. There are a few companies that still use the authentic equipment and require tremendous skill. Just thinking about how to make them work makes my nose bleed. I think that they are similar to the rose lathe mentioned but the examples that I have seen are much more complicated. Thank god for CNC!
    Jul 2003
    586
    Sorry I did a little digging and it turns out that a Rose lathe is also an acceptible term for the lathe that us used to make the Guilloché pattern. Sorry
    Jul 2003
    586
    Just for for the heck of it hear is a link to what the machines looked like.http://goldmachinery.com/machinery/5404.htm
    35494
    That close up pic does NOT look flat to me. Looks similar to this
    http://www.interlam-design.com/index...D=1&clientID=1
    Aug 2005
    597
    Hi Chuck,
    VCarve Pro can certainly be used to engrave these interesting artistic patterns so long as the CNC machine is precise enough with a high speed spindle and precision ground cutters.
    Below are a few patterns that a customer created using VCarve Pro that look 3D but are simply engraved into a flat surface. The key here is to have the artistic ability to draw the design with varying widths between the lines that will result in the 3D engraving toolpath producing the optical illusion on the surface.
    PhotoVCarve works in the same way but the software takes care of the process automatically - would be interesting to see peoples faces engraved onto watch faces using this technique!
    Let us know if you have any questions or we can help in any way,
    Tony
    http://vectric.com/forum/download.php?id=38
    http://vectric.com/forum/download.php?id=37
    http://vectric.com/forum/download.php?id=39
    Apr 2003
    598
    Trust me...it's flat. Watch dials are comprised of flat planes...sometimes 2 or 3 of them stacked, but they're always flat.
    Look where the arabic numerals are attached...flat.
    The decoration technique is called Guilloche, and is magnificent in person. Cheap watches have these patterns stamped...expensive ones are individually cut, and appear much crisper than stamped dials, especially in person. (I carry a pocket loupe)
    I want to try doing this type of thing, myself, for the fun of it. Should be quite spectacular, if I can get it to work.
    -- Chuck Knight
    P.S. Didn't I see a post on this site, by the author of V-Carve? I'd love to get his input.
    Apr 2005
    3634
    Isn't VCarve, Tonys software (Post#10)?
    Apr 2003
    598
    I think he answered my question, while I was writing my post. They're only separated by 11 minutes or so...I use a multi-tabbed browser, so that's probably what happened...he answered while I was reading someone else's post.
    Glad to meet you, Tony. I've never used VCarve...is it downloadable, maybe a trial version? How is the modeling done?
    -- Chuck Knight
    Aug 2005
    597
    Hi Chuck,
    You can download a Trial version off our web site. This is version is not time limited but will only let you save toolpath files for the evaluation files supplied with the software. These files can then be tested on your own machine. The Trial version will open your own designs, calculate and preview the toolpaths, but not save these cnc files.
    Most of our customers are using AutoCAD or graphics software such as Corel Draw to originate the designs. VCarve Pro does include what we refer to as Editing Tools for scaling, positioning, point editing for loops, weld, Text entry and simple shape drawing. The software imports vector file formats - EPS, DXF, AI, PDF.
    For more information on the software + training tutorials etc. take a look at,
    www.vectric.com
    Drop me a note if you have any questions or we can help in any way.
    Tony
    May 2005
    362
    Chuck
    WOW! That is truly a beautiful watch. Not much impresses me but thanks for a twinkle in my eye tonight. Wish I had the money for one of those.
    Nov 2006
    303
    Neat Pattern
    That a unique pattern. I messed around, using ArtCAM, a little and got pretty close to the same thing. I dont see how it could be "flat" with the wave pattern being so pronounced. Still pretty neat. Whats a watch like that cost?
    Nov 2006
    303
    Here's a link to the rendering of the pattern.http://www.innovative-accents.com/watch.html I only spend 15 mins playing around. So its not exact but pretty close.
    35494
    Quote Originally Posted by todd71 View Post
    I still don't think it's flat either. I'd need to see it to believe it.
    May 2005
    362
    Todd
    Pretty cool for 15 minutes of work.
    May 2004
    290
    Nice Todd,
    May I ask how you modeled that (and what program you used)?
    Carlo
Page 1 of 2 12
