587,997 active members*
1,956 visitors online*
Results 1 to 2 of 2
    Apr 2013
    5
    Help! One single shaft stepper to drive y axis.
    I mistakenly purchased a 3 stepper kit, all of them with a single shaft. Now I am confronted with a design issue of how to drive the Y axis. The design I'm following is the Haynes cnc. It asks for a dual shaft stepper for the Y axis. I'm using #35 roller chain and sprockets on either side. The question is how to drive the shaft for these sprockets with one stepper with a single shaft.
    How can I integrate a single shaft, single stepper solution for the Y axis? I considered timing belt and pulleys, but its going to cost more than I budget allows. Is there a cheap solution to this problem?
    To make matters worse, the stepper shafts are 14mm diameter. The Y axis shaft for the outer sprockets is 1/2".
    I know, if only I purchased a dual shaft stepper...
    Thanks in advance!
    :drowning::drowning::drowning:
    Apr 2009
    5516
    Buy a dual-shaft stepper.... cheaper than a timing belt, two pulleys, and fabbing a plate to hold all of it.
  1. Running 2 stepper motors off a single drive
    By laserpilot in forum Stepper Motors / Drives
    Last Post: 12-05-2018, 06:24 AM
  2. Two stepper motors on a single axis.
    By riphet in forum Stepper Motors / Drives
    Last Post: 10-06-2012, 07:21 PM
  3. What is the cheapest option to drive a single axis?
    By Apples in forum CNC Machine Related Electronics
    Last Post: 07-22-2010, 02:00 AM
  4. Dual and single shaft stepper motor differences?
    By Menatep in forum Stepper Motors / Drives
    Last Post: 04-09-2007, 04:22 PM
  5. 4X single axis bi-polar xylotex drive
    By alexccmeister in forum Xylotex
    Last Post: 03-07-2007, 11:53 AM
