603,946 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > ST30 PROGRAMMING ADVICE NEEDED FOR MILLING HELICAL GROOVE, PLEASE!
Results 1 to 6 of 6
    Mar 2011
    8
    I've got to program some jobs with a helical/spiral groove around a bar, (i.e. on the drawing looks like a figure of 8 on its side).
    The last time the job was done (on different dia bar and shorter spiral) several of us had a go at programming it and we all got the same result, effectively, two lines, (i.e. C0 Z-50.; C180. Z-100.; C0. Z-50; , its metric, 50mm pitch helical/spiral groove). it was eventually programmed long hand, (all 360 degrees of movement with z move for each degree).
    There must be an easier way!
    Can anyone help, please!
    Cheers Jim
    Apr 2006
    3206
    You've got 4 quadrants of radii, 2 on each end of the "8", a pair of straight lines connecting them if you want a more elongated "8".
    Don't think you're going to be able to use straight G-code to do this.... you've got to integrate some trig functions into the commands,
    and that means macros. Then the big question is: Did you pay to enable the macro option?
    What about your CAM software, using a "wrap" function?
    (I am, as I write this, looking at the tube I milled in the Mazak with live tooling that has a spiral in the side. Modified the sample in the Mazak manual and
    used it for an open house demo. .... too bad I couldn't extract the G-code that Mazatrol generated to do it...)
    Mar 2011
    8
    i'll take a picture of one of the old ones
    Mar 2011
    8
    Attachment 210802Click image for larger version.
Name:	20131128_121654 (640x360).jpg
ID:	210804Click image for larger version.
Name:	20131128_121704 (640x360).jpg
    Hopefully these photos show the problem
    Nov 2010
    73
    Manufacturer my cad cam program says that the lathe HAAS equipment with C-axis can not be programmed to process the radius of the cylinder using g2 g3. His program does this by dividing the radius of a plurality of straight sections.
    Why silent HAAS? Maybe something has changed? Because of the receipt of this information was six years ago.
    Mar 2013
    12
    If it were the rotary axis on a mill, you could use a G107 to wrap the figure 8 around the rotary part.
    For this kind of milling on a live-tooling Haas lathe, the code will need to be programmed long-hand by a CAM system (lots of synchronized CZ G01 moves)
  1. Lynx 220LM Live Milling Programming Help Needed
    By montie in forum Daewoo/Doosan
    Last Post: 05-12-2014, 08:10 PM
  2. Advice needed on programming this part
    By titanium5150 in forum CNC Swiss Screw Machines
    Last Post: 06-15-2013, 01:56 AM
  3. Ideas upon Internal Helical groove cutting
    By brianklein in forum MetalWork Discussion
    Last Post: 01-12-2009, 06:44 AM
