603,963 active members*
1,793 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Missing Steps - Only in part of Y axis travel
Results 1 to 6 of 6
    Feb 2010
    Unhappy Missing Steps - Only in part of Y axis travel
    A little bit about my machine first. Wanted to do a build thread but haven't been able to find the time yet. I hope to create a thread with the finished project sometime in the future.
    Cutting Area - 48" x 30"
    CNC Router Parts Nema 23 Rack and Pinion
    1/2-10 5-start on Z Axis
    Gecko G540 - 1909.861 steps per inch.
    Super PID V2
    Mach3
    Hitachi M12VC
    Onsrud cutters
    Somewhere in my Y travel, there is a 1/32" worth of missed steps.
    This happens every single time, regardless of moving in positive direction or negative direction. I have taken some pictures to help illustrate the issue.
    Anything cut to the right of this point, is perfect, dead on, within 0.005".
    Anything cut through this point, is always, always 1/32" smaller than supposed to be.
    Its not backlash, since I can cut perfect sized shapes if I cut something small, on the 'right' hand side of the table.
    I can compensate 1/32" larger if I am cutting something large and it will come out perfect size... As a result, I have to cut things in mated pairs.
    If I set the machine to cut something 12", it will cut 12 - 1/32".
    If I set it to cut 24", it will cut 24 - 1/32".
    I've looked and looked for loose parts or something stuck in the rack but I can't find anything.
    This only happens on the Y axis. The X axis is perfect.
    Any ideas? Thanks.
    Jul 2010
    1328
    Is the rack on the gantry one piece or two?
    I'd agree with where mountaincraft is going - if it repeats in the same spot every time, it's very likely something mechanical, like there is a screwed up tooth on the rack for example. If you can isolate the position, look at the teeth on the rack there, maybe using a set of calipers to check the spacing between teeth, and see if there's an error in one of the teeth.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Feb 2010
    It is one piece of 54" rack.
    I will see if I can measure the teeth.
    I've only visually inspected it.
    I agree that it is very likely to be mechanical.
    I'll look closer.
    Apr 2007
    8082
    I think it is likely to be a ding (or rough spot) along the edges of the steel rail, a spot of rust, or bearing preload a little too tight and the steel rail gets slightly thicker at one particular place along the rail edges. Feel the rail edges top and bottom to see if there is a noticeable change in how it feels. Back off a little on the bearing pre-loads and see if the problem goes away.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2006
    3498
    did you find the problem?
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  1. my x axis is missing steps but I found the problem
    By xspyke in forum Gecko Drives
    Last Post: 11-07-2013, 02:57 AM
  2. Missing steps when jogging in more than one axis
    By vonnieda in forum Benchtop Machines
    Last Post: 08-05-2009, 06:23 PM
  3. z axis sticking / missing steps
    By 725franky in forum Taig Mills / Lathes
    Last Post: 04-06-2009, 11:07 PM
  4. Missing steps on just a certain part of the part
    By ZipSnipe in forum Stepper Motors / Drives
    Last Post: 01-02-2008, 08:40 PM
  5. Missing steps ?
    By DavyD in forum Machines running Mach Software
    Last Post: 05-10-2006, 08:06 AM
