603,945 active members*
3,001 visitors online*
Results 1 to 3 of 3
    Aug 2013
    20
    Question X Axis Excess Error
    Hello guys,
    I have a CNC turning machine with control Fanuc 18i-TB
    The machine has 2 axis only Z and X
    I was moving the X axis by JOG in the "-X" direction
    but i excess the limit and the Alarm 411 X Axis Excess ERR appears
    I can't move this Axis back since this error
    I tried to increase and decrease these parameters:
    1829 > Positional deviation limit value when axis stops
    1829 > Positional deviation limit value during movement
    Rapid Traverse Feedrate
    Manual Rapid Feedrate
    JOG Feedrate
    But with no Luck the Axis doesn't move and the alarm 411 appears and the machine make E-Stop state!!
    Also after many tries the alarm 436 X Axis SOFTTHERMAL (OVC) appears !!
    Aug 2007
    849
    your drive thinks that motor get overloaded
    may be he is right?
    check mechanics and lubrication of guides
    also you may check current by servo monitor function
    Aug 2013
    20
    Quote Originally Posted by guhl View Post
    may be he is right?
    Yes guhl you are right the problem is a big load on the x axis
    the effective current is 100% so it generate the OVC alarm
    But i don't know what is the reason of this load ?
    is it in the brake ?
    How can i fix this problem ? will i disassemble the Axis and move it manually to the zero reference position ?
  1. 431 z axis servo excess error
    By bassackwards142 in forum Fanuc
    Last Post: 06-25-2013, 02:46 AM
  2. Mazak QuickSlant 20 with Mazatrol T4 -ERROR 1: SERVO LAG EXCESS X1 AXIS
    By Acustical in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-24-2012, 03:44 PM
  3. Replies: 6
    Last Post: 01-14-2011, 05:16 AM
  4. Alarm 410 V axis Excess Error, FIX?
    By D_Flannery in forum Fanuc
    Last Post: 01-14-2011, 05:13 AM
  5. partner 1 Z axis excess error problem
    By blowncoupe in forum Milltronics
    Last Post: 10-18-2008, 03:20 AM
