603,958 active members*
3,256 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree Journeyman 325 with a delta 20 controller
Results 1 to 3 of 3
    Aug 2010
    7
    I am going to look at buying a Journeyman 325 with a delta 20 controller on Thursday. I was wondering if anybody has a sample program I could use as well as how to load it to test the machine and see if there are faults. I run a tree Journeyman 300 at work but it has a Allen Bradley controller and I also run a Haas VF4 and TM1. I have never programed a Dynapath controller and from what I hear the format is quiet a bit different than a Haas. If there is any other info you can give me to help evaluate the machine I would really appreciate it.
    Jimmy
    Mar 2006
    158
    Re: Tree Journeyman 325 with a delta 20 controller
    I can look through my old manuals to see what I have.
    Let me know if you are interested - as I would have to have them copied.
    And, yes, the Dynapath is a weird duck, but it did have some redeeming factors when doing simple programming at the machine.
    Aug 2010
    7
    I got it working, thank goodness there were some really easy instructions and a sample program that came with it. The biggest problem I had was getting it reference zeroed again because the guy I got it from had it way off. The Y axis kept faulting out in the middle of its travel so I thought it was the Y axis servo but all that was really wrong was the machine was lost. I even took the Y axis servo motor apart and cleaned it before I realized what was really causing it to fault out. Now im working on getting it hooked up to my computer so I can try running some good programs.
  1. help tree journeyman 325
    By cnc beginner in forum Tree
    Last Post: 03-05-2014, 07:13 AM
  2. tree 325 journeyman
    By cncrouter in forum Tree
    Last Post: 01-22-2013, 02:45 PM
  3. Journeyman 425 help? Delta Tau controller
    By chilly2k in forum Tree
    Last Post: 04-07-2011, 10:06 PM
  4. Tree Delta 10MU Controller for Trade
    By elnerdo in forum Tree
    Last Post: 08-29-2008, 01:24 AM
  5. Tree Journeyman 310
    By Gyro in forum Tree
    Last Post: 07-20-2007, 12:40 AM
