603,929 active members*
3,584 visitors online*
Results 1 to 7 of 7
    Mar 2006
    233
    rail problem fixed with a pic!
    well if you remember a short while back I was having an issue with a rail system that I had picked out and bought. It was a pair of 60" unsupported rails in a 20mm Diameter. The rails were to be supported at the very ends with a set of mounts. After hearing from you guys about how the rails will flex and distort under a side load I went and found these, same size rails except supported. They were NOT cheap.
    35494
    Quote Originally Posted by SatanKlawz
    But they sure look nice.
    Apr 2003
    1873
    And good bye to any flex under load problem
    Mar 2006
    233
    yeah, this was susposed to be a little home built machine that was to be constructed with electronics for under $500. Those rails alone were almost that.
    Apr 2003
    1873
    SatanKlawz,
    I am running into the same thing on my project, down the road, neither of us will regret it.
    Ken
    Dec 2004
    1316
    In order to keep the machine consistent the other axes should also have those type of rails, I think you can keep the $500.00 for electronics and motors.
    Do I see ground ballscrews in this machines future.
    Jason
    Mar 2006
    233
    actually it will be acme rod. I am not sure how much of a difference there is but I have all of it already. It is a dual leadscrew design.
