587,999 active members*
2,236 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Problems with feed rate
    Sep 2013
    29
    Hello from Germany.
    -Please use simple english to answer!-
    Because I cant find good informations into the german Forum I try to get it here.
    Normally I mill wood but to build a new CNC Machine I must mill often Aluminiuim. There I need lower feed rate and thats the problem ;o(
    I change the X/Y feed into the tool parameters but in the GCode my Machine uses the old 900mm/min and not the Alu-material-feed from 350mm/min. I must lowering the feed rate at Mach and then all feeds reduce. Also the feeds outside the material...
    If I change the settings to create the Gcode and edit the material feed in the last step (picture) and edit the rate there, then Mach uses the Z-speed from 50mm/min for x/y movings.
    What I must do to get the feed rates I give into madcam???
    Thank you, Ron
    Attachment 235372Click image for larger version.
    Apr 2003
    1357
    Re: Problems with feed rate
    Make your changes to the feed and speed, then make sure to save your changes.
Name:	save the tool.png
    Sep 2013
    29
    Hello.
    I think I sove the Problem but now I have a new question.
    The tool should pull down with a ramp of 40 deg into the material. And I see that the feed madcam uses to make this ramp is the X/Y feed (F=350) and not the Z-feed (F=50). Thats real?
    What I can do to get a lower feed on the ramp?
    Ron from Germany
    Apr 2003
    1357
    The FeedZ is only applicable when the tool is feeding down, approaching the cut. It then switches to the FeedXY rate. The ramp is considered a FeedXY cut. What I would suggest is that you ramp in at lower angle so that the FeedXY is appropriate, and doesn't overload the cutter. For example, when we are cutting steel, we use 2
  1. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  2. Im having problems with feed rate
    By Fluxion in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2009, 12:26 AM
  3. Mach 3 feed rate problems
    By taylorn in forum Mach Mill
    Last Post: 04-28-2008, 12:01 AM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
