603,923 active members*
3,250 visitors online*
Results 1 to 3 of 3
    Hello everybody
    I’d like to bump some flutes in an aluminium base body at a QTN Nexus M. For this purpose I used a manual milling program with that I could pan the C-axis at the exact degree value and then bump flutes with G0 or G1. Now I’d like to call the bumping of flutes as a subprogram and only to turn the C-axis in the main program. But unfortunately I can’t make my Mazatrol to call a mazatrol program as a subprogram. The error 906 always occurs: the wrong address.
    Could anyone help me?
    Thanks a lot
    Oct 2007
    50
    Which controller?
    As far as I know you can’t call a mazatrol program as a subprogram with the controller 640MT. It’s only possible with the Matrix controller.
    Regards
    Stefan
    Jan 2007
    8
    Right, it can’t work.
    But why don’t you copy the clause several times and then just change the degree value of the c-axis in each clause?
    regards
