588,215 active members*
4,115 visitors online*
    Aug 2009
    3
    Unhappy ISSUES DUE TO BATTERY
    HI
    my fanuc 0i-mc vmc is not responding due to battery fault in mornings at the time of start but after ten minutes all alarm go away. But today same problem was there with two more alarms
    1. EMG STOP OR OVER TRAVEL.
    2. TOOL NOT IN POSITION.
    I HAVE ORDERED BATTERY FROM FANUC BUT IT WILL TAKE 3-4 DAYS DUE TO HOLIDAYS THESE ALARM ARE NOT RESOLVING.
    PLEASE HELP.
    Aug 2009
    3
    Re: ISSUES DUE TO BATTERY
    THE OTHER ALARMS WERE;-
    X AXIS SERIAL DATA ERROR (INT)
    FOR ALL AXIS BUT IT GOES AWAY AFTER TEN MINUTES OF STAYING ON AND THEN RESTART.
    PLEASE HELP URGENT.......
    Dec 2008
    3137
    Battery powers the RAM that holds machine data at time of shutdown ( ie current position, current tool, parameters etc)
    - RAM cannot supply the data for morning bootup.
    Battery needs to be replaced ( while powered up ) before any help can be given
    - you may find that the alarms will disappear
    NOTE.....dead batteries in a machine is a big NO-NO.
    - some machines will be boat anchors, due to loss of parameters ( a good practice is to keep a current parameter file as backup )
    Aug 2009
    3
    THANKS SUPERMAN FOR YOUR REPLY
    WELL BATTERIES WILL TAKE TIME TO REACH AT OUR WORKS. MEANWHILE IS THERE SOMETHING THAT CAN BE DONE TO CARRY ON THE WORK BECAUSE MACHINE IS NOT WORKING.
    ALSO HOW CURRENT PARAMETERS CAN BE STORED.
    IS THERE ANY PROVISION TO SAVE THOSE PARAMETERS TO MY FLASH CARD THROUGH WHICH I RUN VARIOUS PROGRAMS IN MY MACHINE.
  1. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  2. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
  3. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  4. Motherboard battery(?) issues, Partner 4 CentV
    By trevj1 in forum Milltronics
    Last Post: 02-26-2011, 07:41 AM
  5. Replies: 13
    Last Post: 07-31-2008, 11:32 PM
