603,785 active members*
18,238 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Any scrap value in Pattern Plank 1052 dense urethane
Results 1 to 7 of 7
    Apr 2007
    47
    Does anyone know if there is any scrap value in pattern plank 1052 which is a dense urethane used for building patterns? The original cost of the material is quite high so figured there could be some value in the used material pieces. If there is no value will a recycling center at least take it so I don't have to pay to dump it? Thanks for any input.
    Feb 2011
    423
    Re: Any scrap value in Pattern Plank 1052 dense urethane
    How much do you have ?
    Apr 2007
    47
    Quote Originally Posted by slowlearner View Post
    How much in weight or size of pieces? I probably have 1000 pounds, maybe more. Haven't pulled them all down off the racks. As for size pieces vary from small to a couple that are 8 inches by 12 inches by 18 inches. The big pieces are made of smaller pieces glued together so they are not solid chunks. These are all patterns. Most are positive/negative so there are some nice chunks of material in them still.
    Apr 2007
    47
    So any interest 'slowlearner'?
    Apr 2004
    5950
    If they are irregularly shaped patterns, then no; not really. But if you cut them into rectangular blocks, then people would probably buy them for small projects.
    Andrew Werby
    Website
    Apr 2007
    47
    Quote Originally Posted by awerby View Post
    I thought about that but is the time and effort worth the money? The offered to give the material to the pattern maker we use who actually made all these patterns but he didn't want to bother either. That could be because he was getting away with charging for starting with new material. Hahahahaaa
    - - - Updated - - -
    Anyone know if this would be considered TPU? (thermoplastic polyurethane)
    Feb 2011
    423
    Sorry Flat but I can't find a use for it at this time.
  1. Dense Mesh Models
    By ssw in forum Rhinocam
    Last Post: 03-10-2014, 08:46 PM
  2. aluminum plank
    By kjl-pdx in forum T-Slot CNC building
    Last Post: 02-01-2013, 06:42 PM
  3. urethane casting resin for pattern making
    By forhire in forum Moldmaking
    Last Post: 07-06-2011, 02:23 AM
  4. urethane molding
    By MBG in forum Moldmaking
    Last Post: 12-12-2010, 01:35 PM
  5. Does anyone know if hardi plank can be machined?
    By zonker in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2009, 05:17 AM
