587,997 active members*
1,977 visitors online*
Results 1 to 3 of 3
    Mar 2014
    8
    RS232 Switch on a New Windows 7 System
    Hello,
    I'm assuming that a number of you gentlemen have already faced this issue and solved the associated problems.
    We've got an old Windows XP system at the shop with an automatic RS232 Switched Port (16 banks ?). We use Griffo brothers to store data offline and other software for drip feeding. Well, the short story is that the XP system decided to go to sleep forever today.
    I have read that many suggest just finding an old XP system and continuing to use that OS. With the age of that operating system and with the new vulnerabilities it opens us up to, I'd like to consider upgrading to a new(er) computer and operating system.
    Can anyone make any suggestions? We've got 2 mills and 4 lathes to connect ASAP. Then more to add as time allows.
    Can I use a USB to RS232 Cable to connect to the switch? Are there any resident drivers in, for example, Windows 7 that would support that switch? Does anyone know if there are drivers available for older serial switches?
    I greatly appreciate any and all suggestions you might be able to offer.
    Thanks,
    Paul
    May 2012
    36
    Re: RS232 Switch on a New Windows 7 System
    I would recommend to use RS232-to-Ethernet converters like MOXA Nport 5110 instead of RS232-to-USB cables. These converters (rs232-ethernet) work much stable than rs232-usb.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Mar 2014
    8
    Quote Originally Posted by HDowns View Post
    Thank you very much for your help. I will certainly check into that converter. Given that a few of the machines are circa 1990, I'm not very sure of what would work best.
  1. M&M Gleason Precision System Gear Measuring Machine with Windows Xp SP1
    By M.RISHIKESH in forum Computers / Desktops / Networking
    Last Post: 05-17-2013, 04:55 AM
  2. Intermittent Limit switch triggering system
    By Capteod in forum Mach Mill
    Last Post: 05-07-2013, 08:51 PM
  3. RS232 on Windows 7
    By salvadoralvarez in forum Controller & Computer Solutions
    Last Post: 08-24-2010, 07:04 PM
  4. Walk through RS232 and windows 2000
    By roger_e in forum Computers / Desktops / Networking
    Last Post: 04-13-2010, 01:45 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
