603,800 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Mobile Base / Shop fox
Results 1 to 2 of 2
    Mar 2013
    3
    Question G0704 Mobile Base / Shop fox
    Hi Guys,
    I've been a lurker for a while and am hoping to start buying parts for my own G0704 CNC build soon (Already bought and read through Hoss's plans). I see that a few people have used the Shop Fox, or some other mobile base, and with all of the steppers, head spacers, 3 Phase Motors, power drawbar, and all of the other enhancements to the base G0704 are you still able to use the mobile base without wobble / stability issues? Any mods to the base itself to make it more stable? Did you loose any precision or get additional chatter from using the base?
    Thanks,
    Will
    Jan 2016
    79
    Re: G0704 Mobile Base / Shop fox
    I've used the Shop Fox mobile base under the stock G0704 stand since initial setup. I've done all the mods and added lots of weight with a larger motor, cnc kit, spacers, fog buster, etc. The base has been very stable. Throughout all the mods it's been great to wheel the mill around to access the column and other parts easily. When the feet are down the base is very stable. The weak link is the stock Grizzly stand which has some flex. A few days ago, I rolled the mill a few feet forward for a good shop vac'ing under and around it. Was thankful for the base.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  1. Grizzly G0704 base size information
    By wheeliecake in forum Benchtop Machines
    Last Post: 10-27-2015, 08:18 PM
  2. PCNC770 mobile base question
    By spletcher1 in forum Tormach Personal CNC Mill
    Last Post: 11-05-2013, 05:43 PM
  3. Mobile Base project for the 66' J-head
    By 79TigerPilot in forum Bridgeport / Hardinge Mills
    Last Post: 04-09-2012, 03:19 PM
  4. Mobile base for IH Mill
    By ProGunOne in forum Charter Oak Automation Support Forum
    Last Post: 01-16-2008, 11:03 PM
  5. Mobile base for the IH: any ideas?
    By deaeni in forum Charter Oak Automation Support Forum
    Last Post: 07-30-2006, 02:25 PM
