587,089 active members*
3,008 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Anyone here have a BCVer25 PP that outputs functional g76 code for Mach3?
    Oct 2005
    278
    I have BCVer25 running a lathe controlled by mach 3. most things are working fine, but the G76 outputs from the BCVer25 PP are totally wacked out.
    Anyone have a text file of their PP for mach 3 that have good G76 output?
    I would really appreciate the help.
    Nate.
    Nate.
    Ann Arbor Meechigan
    Jun 2007
    394
    Re: Anyone here have a BCVer25 PP that outputs functional g76 code for Mach3?
    Not been able to successfully get G76 or G96 working from BobCAM V4. I believe G96 does not work in Mach 3. Not sure about G76 but if you want I can send you my edited lathe post processor to try?
    Jun 2008
    1838
    Quote Originally Posted by nate View Post
    Nate.
    Nate
    Lot depends on which version of Mach3 you are using and there is some setting up to do, personally I just use the good old "simple threading" G32 method but if you want some brain pain then have a look at this PDF file for all the answers to G76 threading on Mach3
    http://www.micro-machine-shop.com/Mach3%20Threading.pdf
    I`m afraid it is a matter of finding out the correct G76 configuration for your version of Mach3 and then it should be fairly easy to mod a PP up to suit
    P.S. The line in the PP that sets the G76 config is Line 87, see below :-
    87. Start of thread (G76) cycle
    n,"G76",thread_x2,thread_z2,thread_lead,thread_fir st_cut,thread_angle_in,profile_start_x,profile_sta rt_z,rough_retract_amount,thread_last_cut
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Oct 2004
    832
    G76 works great for me, I altered the PP to suit but as I use metric it may need modified further if you use Imperial units.
    Anyway looking back at a V25 post I have I see I altered 2 entries, first is line 87 and second is I made a programme block, I used Programme Block 5 (line 2005 in PP) as I already had 1 to 4 used for other things.
    Here is what I had.
    n,"M49"
    n,"G76","X",program_block_5,thread_z2,thread_lead, thread_first_cut,thread_angle_in,rough_retract_amo unt,thread_last_cut
    n,"M48"
    And
    2005. Program Block 5.
    StartX = LATHE_Getprofilestartx()
    Pitch = LATHE_GetThreadLead()
    EndX = LATHE_GetThreadX2()
    If EndX < StartX then
    height=(StartX*2)-(Pitch*1.226)
    Else
    height=(StartX*2) +(Pitch*1.17)
    End If
    height = FormatNumber(height ,3)
    LATHE_SetReturnString(height)
    Hood
  1. mach3 crashing with run of code/drilling holes through table with other code
    By normalform in forum Mach Software (ArtSoft software)
    Last Post: 07-28-2014, 03:38 AM
  2. Mach3 parallel port outputs
    By Drools in forum Mach Software (ArtSoft software)
    Last Post: 09-10-2012, 01:12 AM
  3. What m-codes control relay outputs in mach3?
    By jedcam67 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2007, 02:37 PM
  4. Non functional E-stop
    By js412000 in forum Safety Zone
    Last Post: 05-21-2007, 06:44 AM
