I'm in the process of trying to setup a lathe tool library in SC10 for my new 15L lathe which will use turret and gang tooling. I've created a new library and am trying to populate it with some of the standard index tooling that Tormach sells. In the Tool Library tab, under Parameters for a turning operation, I see entries for Inserts, Toolholders, and Turn Tools, each of which leads you to a dialog box where you specify the corresponding component. I've added inserts (say CCGT 3(2.5)2 and toolholders (say SCLCR 12-3C) which specify the geometry of the insert and the toolholder but there doesn't seem to be a way to assign those to a specific turret position or to each other. The Turn Tool dialog box does allow a way to assign a tool to a specific turret position, but the tool definition requires geometry to be entered from scratch and there seems to be no way to use the insert and tool holder data from the other dialog boxes.
Has anyone figured out if there is a way to get these 3 type of data to be used together for turning operations?
Attachment 302008
