587,137 active members*
3,387 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Problem: Probe Tool connection in Mach3 with C-10 Board
Results 1 to 3 of 3
    Apr 2011
    43
    Holly Platypus! I tried to connect a prove plate to my C-10 board (see attached jpeg ) from pin # 12 to the plate and ground connection to the spindle. However, the digitized light in Mach3 Troubleshooting Tab is on without the plate been connected. I tried the input jumper-up, the probe works but not the e-stop or the limit switches. Please refer to the attached jpeg and advise. Thank you
    Nov 2012
    1270
    Re: Problem: Probe Tool connection in Mach3 with C-10 Board
    Most likely, you just need to add a pull-up resistor between terminal 12 and +5V. You may also need to disconnect (desolder) the existing pull-down resistor on the board.
    Apr 2011
    43
    Hello COD: I'll contact Automation Technology to see if they can advise the resistor type and where I can buy it. The desoldering route will affect my E-Stop and L/Switches. Thank you
    Sent from my LGMS210 using Tapatalk
  1. 6040 Touch Probe Connection Place on this Breakout Board?
    By mikejohn37 in forum CNC Machine Related Electronics
    Last Post: 07-18-2018, 12:19 AM
  2. Alternate way to setup tool probe in Mach3
    By Kutton in forum Mach Mill
    Last Post: 09-24-2017, 05:22 PM
  3. mach3 ScreenSet blue Big-Tex problem feedrate probe.
    By easystar in forum Mach Wizards, Macros, & Addons
    Last Post: 12-13-2016, 09:50 AM
  4. Replies: 1
    Last Post: 11-04-2016, 04:22 AM
  5. 5-axis CNC Breakout board and problem with connection display module
    By lasek in forum CNC Machine Related Electronics
    Last Post: 05-23-2013, 09:52 PM
