Re: help geckog540 machs 3 spindle wiring
goorus,
You can test the VFD output by connecting a 9V battery (or any straight DC voltage that is around 10V) between VFD IN and VFD GND and measure between VFD OUT and VFD GND with a voltmeter. You would then want to toggle the VFD signal in your software and see if you get a voltage change on your voltmeter. If you do, then the fault will lie with your VFD controller. If you do not, you will want to disconnect the DB25 from the G540 and measure the VFD pin on the cable to see if it is outputting any signal. If that is outputting the correct signal then the problem will lie with the G540; if it is not then it is a software setting that is not correct.
I think I may have typed that a little too run-on-sentencey so if you need me to clarify just let me know.
Marcus Freimanis
www.geckodrive.com
