587,534 active members*
3,512 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Drilling with Live Axial Tooling on HAAS Lathe
    Jul 2016
    I'm new to HAAS live tooling programing and finding it frustrating to work out on my own. At the moment I am just trying to drill a hole right through the middle of a part with a 3/4 end mill. I'm currently using G83, only because I don't know what else to use. I can't find a clear example of simply drilling a hole anywhere and it's frustrating because it's so simple to do on my Mori. Here is the exact program I'm using:
    M01
    T303
    G98
    M154
    G00 G54 X6. C0. Y0. Z1.
    G00 X0. Z.25
    G97 P1500 M133
    M08
    G83 G98 C45. Z-.660 F5. Q.15
    C135.
    C225.
    C315.
    G00 G80 Z.5 M09
    M155
    M135
    G28 H0.
    G00 X8. Z10.
    I built this code following an example I found online but it isn't working. It throws an alarm right after the C Axis engages. It says the "V Axis Disabled." I've tried several different variations, but each time I get an alarm. Please advise on how I should go about this.
    Dec 2012
    395
    Re: Drilling with Live Axial Tooling on HAAS Lathe
    Maybe the Haas PDF can help.
    Regards,
    Heavy_Metal.
    Attached Thumbnails Attached Thumbnails Haas-Lahe-LiveToolOpProgram_w_DS-Manual.pdf
    Jul 2016
    Turns out the problem was in the parameters, 315 to be exact. Found the answer within the manual you sent, thank you.
    Dec 2012
    395
    Check this website for other HAAS manuals.
    Haas Automation
    Regards,
    Heavy_Metal.
  1. Alignment of live tooling in a DS30ssy haas lathe
    By carguy001 in forum Haas Lathes
    Last Post: 07-25-2013, 04:29 PM
  2. Haas lathe live tooling Surfcam post?
    By kentw in forum Surfcam
    Last Post: 04-30-2013, 03:47 PM
  3. CNC Haas Mill/Lathe Set-up/Operator with Live Tooling - IL
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 11:06 PM
  4. Haas OL-1 Live Tooling
    By Jorge-D-Fuentes in forum G-Code Programing
    Last Post: 07-17-2007, 07:09 PM
  5. haas live tooling
    By tgooding in forum Haas Mills
    Last Post: 12-07-2006, 02:58 AM
