Hello all,
I need some advice for a small run of parts I need to cast.
The part is essentially a hollow hemisphere with a flange and o-ring groove and a filling port.
For scale the sphere diameter is 170mm (~7") and the wall thickness is 5mm (~1/4").
I need to make around 10 of these parts and a key factor is that they are as dimensionally accurate as possible. They need to be rigid and transparent, so I'm thinking of using a resin.
Attachment 352816Attachment 352818
My concern is how best to produce the moulds for casting. I think it needs to be a two part design, but if I use silicone I worry that the large mass and cavities of the moulds would not remain dimensionally accurate.
(This is just a concept section view to illustrate the point, I haven't designed the mould yet)
Attachment 352820
Does the mould need to be flexible? Could I just get the two mould halves CNC machined / 3D printed from a rigid material, or would removing a rigid cast from a rigid mould be too difficult?
