588,049 active members*
4,122 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > CNC Masters 1440 lathe software upgrade
Results 1 to 2 of 2
    Mar 2006
    51
    I have a new 1440 lathe from CNC Masters. Once the bugs were worked out (limit switches) I have begun to make nice parts. The trouble with their software is lack of conventional G code in threading cycle. G76 = Threading cycle—FORMAT: X_Z_I_K_D_A_P_F_—Z-FINAL DEPTH; X-POSITION OF; I-TAPER; K-TOTAL DEPTH; D-1ST PASS DEPTH;A-THREAD INSERT ANGLE; P-COMPOUND INFEED; F-FEED IPM. No way to program number of spring passes so I'm left with having to run the entire program 2 or three times to finish depth. If the encoder does not burp and leave me with a different Z distance.
    I looked high and low for a cnc lathe that can be used manually also and found only this one. Lots of power and heavy enough to turn and work on gun barrels with out too much chatter.
    My REAL question: is there a way to introduce a new software to the machine? The 1440 is really a retrofit Chinese gear head lathe with step drive and a spindle encoder.
    Mar 2006
    51
    Re: CNC Masters 1440 lathe software upgrade
    I spoke with Omar at CncMasters and he has sent me a updated software with my suggested mod to the threading cycle and drilling cycle with spring pass and more control with the new controller. They have gone out of their way to listen to customer feed back and respond. I still really like this lathe
  1. CNC Masters software error
    By Miss_yablabo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2020, 05:16 PM
  2. ProtoTrak 1440 Lathe
    By Ridehd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-10-2014, 02:53 PM
  3. CNC MASTERS Master Operating Software
    By awchappell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-21-2011, 06:25 PM
  4. CNC Masters upgrade for the RF-45 mill
    By mikefayettev in forum Charter Oak Automation Support Forum
    Last Post: 05-28-2010, 11:24 PM
  5. Replacement parts for Bermingham 1440
    By cecil1212 in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2008, 05:48 PM
