https://www.eaglecnctec.com/products...ng-Center.html
ATC CNC router has another name of CNC router machining center or woodworking machining center. EagleTec-1530CATC is equipped with carousel type auto tool changer. Tool bank has 8 tool positions. This wood router is good for jobs which needs multiple milling tools to finish. Simply because, auto tool changer optimizes the progress of tool changing to reduce the time cost on it. It makes tool changed automatically, instead of tradition way by manual. This point also is the difference between ATC type CNC router and basic type router machine. To get an clear idea on the above details, here is the URL of its working process for your reference: https://youtu.be/ql7Jr8HmklI
Application
Materials: Solid wood, MDF, plastic, PVC, acrylic, other nonmetal materials and colorful metal like aluminum, copper.
Field: Panel furniture, Office furniture, Cabinet, Closet, Wood door, Bed, Wall art dector panel.
Main Configuration
1) Carousel type tool bank, 8 tools total
2) Origin Italy HSD 9.0kw ATC spindle, 0-24,000RPM
3) Servo motor and servo pack – Delta or Yaskawa
4) Taiwan SYNTEC controller
5) Planetary gear box
